will not shift into 3rd
Car: 1987 Camaro
Engine: 350 5.7 TPI
just go the camaro running took it out today and the damn thing wouldnt shift into 3rd. It shift into 2nd fine but around 2500 rpms it just revs couldnt get above 25mph on the way home. it rode fine cruisin the other day. there is a weird noise sounds like a vacuum? the engine was just rebuilt got it back the other day. Any ideas?
HELP
HELP
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: will not shift into 3rd
I'll assume this is a 700r4. Don't push it you can burn out the clutch bands. I'd recommend calling probuilt automatics on Monday. Dana should beable to help you troubleshoot it.
do you have enough fluid in it?
is the tv cable set?
chances are high that it's not either
welcome to a very common failure in the 700r and 4l60
your 3/4 clutch is gone and it's time to rebuild
it's old and tired.
it's old and tired.
Car: 1987 Camaro
Engine: 350 5.7 TPI
well i guess im just gunna have to keep my fingers crossed.
could replacing the vacuum modluator be worth my while?
any trouble shooting tips?
once it hits 2500 rpms just reving
Received 1,670 Likes
Basically, time for a rebuild.
Now would be a GREAT time to acquire a marketable skill. Instead of being terrified of auto transmissions, tackle it and master it. They're not that hard; just some mechanical stuff that moves around, not hard at all. Once you get past the "it's too hard I don't understand it I gotta pay somebody else out the a$$ to do it for me I can't afford it can't I just put in a Turbo 350 anybody got a junk one cheap can I use one outta a S-10" kind of mode, you'd be surprised how much LIFE progress you could make.
Go here http://www.bulkpart.com/Merchant2/me...ode=4L60-700R4 get you a kit and the ATSG manual (the best in the business), and be proud of what YOU can accomplish.
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If you are a gambler then you could do a minimalist fix.
Pull the trans pan and check for metal
Pull the trans
Pull the 2-4 servo
Stand the trans on its rear with the output shaft having no pressure
Measure the end play and pull the pump.
Pull the reverse and input drum.
Check the forward clutch and 3/4 clutch - probably a smoked 3/4 pack
Install the 3/4 clutches, drums, pump, servo and be back on the road
Order up the 3/4 cluthes & steels, 2-4 band, paper & rubber kit or just lip seals/pump gasket/pump bolt gaskets, filter kit. If you pre-ordered betting that just the 3/4 clutches were bad then you could disassemble and reassemble in less than an hour and fix for less than $100. Take pictures upon disassembly and measure the clutch clearances.
WIT transmission or Makco transmission has online parts
Pull the trans
Pull the 2-4 servo
AmpleUnicorn88
Interior Parts Wanted
16
11-29-2015 05:45 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
Chad Speier
09-24-2015 12:32 PM
