TV cable, any way to delete???
Old 07-13-2011, 10:15 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
All in the title, I swapped plenums and don't feel like trying to get the TV cable to play nice, they are finicky things and getting the engine throttle cable rigged up right was tricky enough, I am wondering if there is any way to get rid of the TV cable, an alternate method to the same end I suppose, though I rather doubt there is.
But I would also like to know just exactly what its for, afaik it just modulates line pressure based on throttle, which leads me to believe that hypothetically I could lock in the line pressure to a set # but would have to sacrifice certain shift qualities at certain RPMS. Look forward to some input on the matter.
Old 07-13-2011, 10:19 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: TV cable, any way to delete???
Maybe a constant pressure valve body? TCI offers them. I am not sure if they eliminate the TV cable all the way...Thier not that hard to get lined up just be patient
Old 07-13-2011, 10:33 PM
Engine: 3.8, 3.4
You don't understand the problem has nothing to do with adjusting the cable itself, I swapped plenums, the only way I can use it is a custom bracket, I don't have much to work with towards the end. Trying to piece together a bracket out of odds and ends isn't easy, I'm still amazed I managed to pull it off for the engine throttle. I'll look into that valvebody though.
Old 07-13-2011, 10:43 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
oh ok. sorry man. Good luck with it either way
Old 07-13-2011, 10:52 PM
Engine: 3.8, 3.4
I checked into the constant pressure valve body, it says you still need the cable but implies that the only thing you need it for is proper shift points, I wonder if there is a manual valve body with constant line pressure, or if it by default would be a constant line pressure...
Old 07-13-2011, 11:11 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
you might wanna message or wait until Dana from Pro Built see's this. I did a serach on google and someone on a 4x4 forum said he eliminated the tv cable with a manual valve body but the shifts are real harsh, he said they now offer a full automatic one but didnt provide a link to one.
Old 07-14-2011, 12:23 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Do you think possibly maybe that fabbing a bracket for proper tv operation is a little easier / cheaper / more sensible than wanting to build up or buy a transmission custom built to operate at high line pressures? Just a thought.
Old 07-14-2011, 09:56 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Dana never has good things to say about the constant pressure valve bodies. Atleast not what I have seen.
Like just mentioned, why spend $300 on a valve body when some time, fab work, and patience can get you a bracket????
Old 07-14-2011, 11:26 AM
Engine: 3.8, 3.4
I want a manual valve body anyways, so if i can kill 2 birds with 1 stone i will. and at the time i asked i didnt know what options if any where out there, so its not like cost was known.
Old 07-14-2011, 11:37 AM
3rdgenmaro's Avatar
Car: 88 IROC
why do you want a manual valvebody? A transgo shift kit will let you manually shift the trans whenever you want it. And you can still put it in D and let it shift on its own. Just think you will get tired of the constant shifting. Plus forget to downshift and risk burning the clutches up quick.
Manual valvebody is not like driving a manual trans.
Just my opinion, its your car and your money.
Old 07-14-2011, 11:43 AM
Engine: 3.8, 3.4
I'm taking an all thrills and no frills approach to my car, sacrificing a lot of luxuries for performance, I would just rather have a full manual VB, its just better if you're going to manually shift all the time, to me a manual auto is the best setup for pure performance, since a true manumatic(the new manuals with automatic clutches) isn't a viable option afaik, pretty sure no one makes one that would bolt up, they are by far the best of both worlds though, lightweight and less parasitic than an auto, but still unerringly precise and quick to shift.
Old 07-15-2011, 12:12 PM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
i had a reverse manual valve body in my dodge charger,and ill tell you if you drive it much on the street its a a##ache, and im more willing than some to put up with hassle in the name of performance- stick with the transgo shift kit and when the thrill of shifting manually wears off just stick it in drive!
Old 07-15-2011, 12:38 PM
Drac0nic's Avatar
The easiest way to do a 700R4 but no TV cable is install a 4L60E. That being said it presents its own challenges.
Old 07-16-2011, 08:13 AM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Summit Racing has what you need as far as tv cable brackets and linkage, and it's not that expensive.
Old 07-16-2011, 09:52 AM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
Best answer yet. Quit making a mountain out of a molehill, its cheaper and easier to buy a bracket and fab it to work than try to modify the trans considerably and try and live with the consequences of a trans that doesnt perform like its supposed to.
Old 07-18-2011, 01:23 PM
Engine: 3.8, 3.4
Something tells me they won't have a bracket for a 4th gen 3.4l v6 installed into a 3rd gen. That being said, I am looking into using the 3.4 bracket but I can't find anyone that sells the damned cables for it.
Old 07-18-2011, 01:48 PM
Did you try Summit Racing? Call them and explain your problem. They may have the answer. I think they refer to the help desk as "Professor Overdrive". I'd give them a call.
Old 07-20-2011, 06:34 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Bowtie Overdrives | TV Made EZ some
some light reading on the function of TV cables
TMZIrocZ350
10-07-2015 12:09 PM
jaridjohn
10-05-2015 07:01 AM
djmarch
10-02-2015 10:41 PM
Zell1luk
09-29-2015 10:36 AM
Quick Reply: TV cable, any way to delete???
