HELP!!!Anyone know about the 4l60e?
i know this is a third gen site , but i have been searching for days for info on the 4l60e tranny in my 94 z28 i just bought.it has no engine.i was told the tranny is good(if you trust sellers) it has a big stall(i know it does cause it like an 8" converter) so to use it i got to at least buy a converter.and a dipstick and tube(missing in action..lol) my question is i plan on running a carbureted 350 in it.it has some sort of tps adapter on the fenderwell. they said they had a carbed motor in it before.will it work?what does the computer need to work the tranny properly?just the tps , the vss , and the tach?will the tach feed off my hei work as an input?i want to use all the factory gauges , even though they already ran some aftermarket stuff.i dont mind buying stuff if i know it will work.i would even rebuild it if i knew it would work right.any help will be greatly appreciated!
Re: HELP!!!Anyone know about the 4l60e?
wow this is like the third forum i have posted this in, and no answers.i guess noone knows the answer out there?maybe i will be everybody's guinea pig?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Try probuilt automatics forum. Dana runs it and he or some reader over there should know.
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you need to get a tci or equivalent tcm to run it. itll run in safe mode missing most of the info it needs from the sensors.
