12 bolt - Third Generation F-Body Message Boards
12 bolt
Thread Tools Search this Thread
Old 10-17-2011, 09:39 PM   #1
84TransAm383's Avatar
12 bolt
Im looking to buy a new 12 bolt or 9 inch but had few questions hopefully someone can answer.
The strange only accept 97-02 brakes and want to no if i can just by the calipers and all from pepboys or something and slam em on my 84.
Also the rear is a inch wider and wanted to no will my rims and tires still fit or will they stick out and hit the wheel wells. They 15x8 with 4 inch backspace
Any info on the swap will be helpful in all ways
84TransAm383 is offline vBGarage Page   Reply With Quote
Old 10-18-2011, 12:07 PM   #2
robguitargod1's Avatar
Car: 86 Camaro, 89 IROC, 87 Cadillac
Engine: 355 SBC
Axle/Gears: Currie 9" 4.57 gear, detroit locker
Re: 12 bolt
You can buy the rotors/pad/calipers from a parts store, but you'll be missing the backing plates and parking brake drum. I bought mine from this guy, and everything worked out well:
http://www.ebay.com/itm/98-02-Camaro...item48416d1805
Offer him around $150, that's what I did. You'll still need to come up with your own parking brake cable solution. Here's what I was able to do with the LS style cables and our stock cables.:
http://www.thirdgen.org/techboard/br...-ls1-swap.html
The extra inch won't make much difference and you probably won't notice.
robguitargod1 is offline vBGarage Page   Reply With Quote
Old 10-18-2011, 11:14 PM   #3
Re: 12 bolt
i wasnt really worried about the ebrake system. Is it ok to leave it unhooked or does it have to be. It hasnt been hooked up on my 7.5 in three years
Old 10-18-2011, 11:16 PM   #4
Engine: 355 SBC
Re: 12 bolt
It's not an e-brake, it's a parking brake and it should be used every time you park regardless of your transmission.
Thread Thread Starter Forum Replies Last Post
ARP Exhaust Header Bolts MY87LT Aftermarket Product Review 13 06-07-2016 10:47 PM
Help please? TPI/Vortec head bolt/valve spring questions. JHX TPI 4 09-13-2015 07:44 PM
Need help identifying 10bolt rear end Numbah-1 Transmissions and Drivetrain 19 09-12-2015 09:57 PM
Scared to snap header bolts need help Jlanz55 Exhaust 7 09-06-2015 08:28 PM
Need feedback on best 10-bolt ring and pinion manufacturer UltRoadWarrior9 Transmissions and Drivetrain 3 09-02-2015 09:24 PM
Go Back   Third Generation F-Body Message Boards >
Tags
12, bolt, gen, members, rebuilt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
