How much tranny fluid?
Old 11-14-2011, 01:54 PM
trevorsmith82's Avatar
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
Im wanting to change my filter but what I need to know how much tranny fluid should i replace? If my total capacity is 9.5 qts how much stays in the valve body and convertor.
Transmissions is a THM200C by the way
Old 11-14-2011, 02:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: How much tranny fluid?
Its similar to an oil change, you don't get allot compared to what it all holds.
I can tell you in my RP thread, it took near a whole 5gal jug to fill a rebuilt 100% empty everything trans.
Old 11-14-2011, 03:06 PM
torque_is_good's Avatar
on the 700R4 you use about 4-5 quarts with a filter change dropping the pan.
On a rebuild and new TC, it uses 12 quarts
maybe that will give you some ideas
Old 11-14-2011, 04:13 PM
Thanks for the info, this is my first time working with a rwd auto transmissions.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
HoosierinWA
10-07-2015 10:15 AM
bjpotter
10-04-2015 07:48 PM
meeklay812
10-01-2015 03:46 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: How much tranny fluid?
