t5 trans neutral saftey switch?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
getting ready for a t5 swap in my 92 (v6). I see the trans has no neutral safety switch? i thought they did, is this correct?
Re: t5 trans neutral saftey switch?
There was a switch. If you look at the clutch pedal on the third gen pedal assembly you can see where it's installed in the pedals.
I think it's the big fat purple wires going to the automatic trans gear selector that have to be extended down to the new neutral safety switch.
If you dont want to bother, you can just run those two wires into each other and bypass it altogether.
yes i know about the pedals, but there is none on the trans itself corect?
the pedals have factory wiring by them for the NSS, i have the pigtails and everything for that.
Received 1,668 Likes
Right: none on the trans, only the clutch.
After all, it doesn't much matter for the purpose at hand what gear the trans is in, if the clutch is to the floor, eh?
No indeed, the T-56 doesn't either... can't say I've ever seen a trans that had one there. But then I've never worked on a TKO. Must be intended as a way to "retrofit" that function into a vehicle that lacked the clutch one to begin with. (i.e. an auto -> stick swap)
1992 Trans Am
05-10-2023 07:19 PM
The_Phoenix
02-04-2016 07:10 AM
eightsixseven
08-14-2015 03:09 PM
