3-4 snap ring on 700-R4
Old 03-24-2012, 05:19 PM
Roadghost's Avatar
So I installed Alto 3-4 clutch pack in my tranny and there isn't enough clearance for the original setup. The kit came with a .062" snap ring to allow for the proper clutch clearance. My original snap ring is .093"
If I use the .062" ring obviously it has some slight free-play in the case groove. Has anyone had a problem with this snap ring breaking out of the groove because of the free-play? Should I go with a different backing plate and use the .093" snap ring?
Old 03-24-2012, 06:00 PM
jonarotz's Avatar
Car: 91 Z28
Re: 3-4 snap ring on 700-R4
You will be fine using the thinner snap ring.
Old 03-26-2012, 09:01 PM
Roadghost's Avatar
Well it's together now. Hopefully I won't blow parts all over the inside of the trans with the first hard shift.
Old 03-26-2012, 09:04 PM
jonarotz's Avatar
Car: 91 Z28
Nah...I've ran them behind some big HP engines without any problems.
Old 03-27-2012, 06:30 PM
Roadghost's Avatar
Thanks for the reply. Greatly appreciated.
LT1Formula
10-08-2015 08:34 PM
TMZIrocZ350
10-07-2015 12:09 PM
gord327
10-03-2015 01:25 PM
FormulasOnly
10-02-2015 05:52 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 3-4 snap ring on 700-R4
