Axle end gears?
Car: 1985 Camaro Z28
Engine: 355
Axle/Gears: 7.5 with 4.11 gears
Axle end gears?
I have a 85 Iroc with a 26 spline 7.5 rearend. I want to upgrade the axles to 28 spline. Can I buy a set of axle end gears to swap out so I don't have to buy a new posi unit. I plan on buying a set of moser axles if I can change the gears, if not I guess I'll have to try to find a 88 or newer rearend. Any help would be great!!
Received 1,664 Likes
Re: Axle end gears?
28-spline axles won't fit through the hole in the carrier far enough to even get as far as the side gears.
So no, you can't do it that way.
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
