what kinda flywheel for my 97 ss t56 on my 89 tpi iroc???? lt1 or ls1???
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Looking to see if a ls1 or lt1 flywheel is the same and if i can use either one for my 97 t56 on my 89 irocz??? I know i got to get it neutral balance.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: what kinda flywheel for my 97 ss t56 on my 89 tpi iroc???? lt1 or ls1???
an LS1 flywheel won't bolt to a gen 1 small block.. if you have the stock engine or any other 86 and newer small block, then you need an LT1 flywheel. if you have an 85 and older 350, then you will need a 12.75" flywheel that is compatible with the LT1 clutch setup.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The 97 should have had a LT1. Use the LT1 flywheel with your 89 motor.
The LT1 is internally balanced the same as a 350.
As long as it's an 86 and newer 350, you should go with everything 97 V8 Camaro. flywheel, clutch, transmission, hydraulics and pedals.
Any LT1 or LT4 is an 86-up 350. Same balance. Same flywheel compatibility. They are all internally balanced which includes the unbalance weighted flywheel.
If your 89 350 was indeed changed from stock balance to neutral balance flywheel compatible balance, you gained nothing and you can't buy an off-the- shelf flywheel.
Sanjay
08-12-2015 03:41 PM
mustangman65_79
08-11-2015 03:17 PM
