Just installed new 3.23
Old 09-22-2012, 07:55 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Converted from a 2.73 open diff w/ drums to a 3.23 posi w/ discs .I got the rear end back on Friday with all new bearings and seals. Got it painted up except a little touch up where it was sitting on the jackstands. New BMR control arms and panhard. I think it turned out very well (It should with the cash I dropped into it lol)
Now next I have to get the mounting hardware and get the sway bar in. Then its on to tackle the brakes and p cable, and the rear will be just about done.
Old 09-23-2012, 12:39 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Just installed new 3.23
wow thats nice! How much did it cost to convert?
Old 09-23-2012, 06:11 PM
Thanks,
I have about a grand in it. And still need just a few things like the mounting kit for the sway bar, calipers and p brake cables.
Old 09-23-2012, 10:45 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Very nice but why 3.23s ? I highly recommend this support cover to protect your investment, I did,very high quality. = http://www.jegs.com/i/L.P.W./619/301-7.5G/10002/-1 and http://www.lpwracing.com/Diff_Cover_...omparison.html
Old 09-24-2012, 05:25 PM
Why not 3.23?
Old 09-24-2012, 05:27 PM
And expensive. Maybe will get one later. So why not 3.23 ? Its a good mid range gear and I got a decent deal on it. Needed to get the car back on four wheels. Winter is near and I need to do some rearranging in my garage to be able to work on the car without a bunch of stuff in my way.
Old 09-24-2012, 09:25 PM
Engine: TBI,5.0
Don't get me wrong, I know how much work you have put into that rear end. I did a complete rear end rebuild using new parts so I may have had a broader range of choices available to me than you had. I guess it just depends on what you consider to be best for your situation. If that ratio fits you than so be it. The more horses you have the more you can take advantage of that ratio.anyway and according to your signature you may be pushing more than a stock 5.0 by the time your done.
Old 09-24-2012, 09:41 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Does anyone know if they make that rear end cover for the 9 bolts? I like the look and function.
Old 09-24-2012, 10:19 PM
Engine: TBI,5.0
http://www.hawksthirdgenparts.com/pr...nt-gasket.html
Old 09-25-2012, 06:02 AM
Im going to be putting a built 350 in it. I can always change it later if it does not perform like I want.
Old 09-25-2012, 09:24 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Ah hell it will probably be just right for you.
Old 09-25-2012, 06:25 PM
Engine: TBI,5.0
I agree
Old 09-25-2012, 08:20 PM
Well thanks for the input guys, Im still learning these 3rd Gens and contructive critisism is always welcome.
Orr89RocZ
04-25-2016 08:28 AM
deracer
04-11-2016 12:04 AM
Bubbajones_ya
08-28-2015 02:17 AM
hectre13
08-26-2015 08:17 AM
Regal105
08-23-2015 03:45 PM
Quick Reply: Just installed new 3.23
