HELP!!! Possible Transmission Problem
Old 11-11-2012, 07:36 AM
Kevinfiscus's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: Automatic TH700R4
I have an 1984 Z28 with a 305 HO engine (computer controlled carburetor) and an automatic transmission. When driving "normally" or even moderately aggressively, the car runs fine. When I put the gas pedal to the floor however, the car accelerates through first gear but instead of changing into second, the power and the RPMs drop significantly and the car won't shift into second. If I take my foot off the gas, the car shifts into second fine. If I am driving in second and plant the gas pedal to the floor, it downshifts into first but then when it tries to shift into second, the same problem occurs. I recently rebuilt the carburetor, changed the transmission filter/fluid and changed the ECU chip, none of which corrected the problem. Any thoughts, suggestions or ideas would be appreciate.
jhawkeye
05-25-2022 06:33 PM
AussiePr0nCar
03-06-2020 04:04 PM
Cleotiz
01-06-2018 08:56 PM
BlackphantomZ28
04-24-2016 08:14 AM
smokingss
LSX and LTX Parts
03-03-2016 07:40 PM
Quick Reply: HELP!!! Possible Transmission Problem
