2- 700r4 trannys
Old 05-05-2013, 06:02 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
2- 700r4 trannys
Is there a "better" one in terms of years? I have one from a 1985 Camaro, and one from a 1991 Firebird. Also, i completely deleted the ecm, and wire harness, so i assume using the ALDL for the TCC lockup will not work,,,,correct?
Thank you!
Old 05-05-2013, 06:50 AM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: 2- 700r4 trannys
86-93,us considered the years gmt perfected the 700r4. Changes to the valvebody and added splines to input/output shaft from what I can remember.
Old 05-05-2013, 06:52 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
They were in continuous development thru the 80's, with some major changes in 87. Go with your 91.
The ecm will no longer control the tcc of course, but you should still be able to engage it by grounding the ALCL pin in 4th.
Old 05-05-2013, 06:55 AM
weesel72's Avatar
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Thanks for the info! So i can go the ALDL route with a switch even though the ecm and wire harness is gone?
Old 05-05-2013, 10:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
So long as the + feed from the brake switch to the tcc, and the return wire from the tcc to the aldl, are still there. Don't know if this is part of the removed ecm harness or not.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
bjpotter
10-04-2015 07:48 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 2- 700r4 trannys
