B&M Megashifter question.
I have an 85 camaro that I bought as a rolling chassis, and it has a nice b&m megashifter in it that I want to use. It has "park,r,n,d,2,1" as the shift pattern. I plan on using a 700r4 because I have one, will this shifter work? All the info I find on these says that they are universal for th350, th400, and 700r4, but how does this work if one is a 4 speed and the others are 3 speeds? Sorry if this is a dumb question but I just don't know and can't seem to find an answer
Re: B&M Megashifter question.
i think you need a 4 speed specific shifter.
maybe something like this;
http://www.summitracing.com/parts/bm...t/model/camaro
If it is a Megashifter Specific for the F-Body it has a lock roll pin you remove for using with a 4 speed auto and it comes with a new sight that shows the overdrive position.
Ok so there is an adjustment in it that I can set it up for 4 speed, and I would just need to get the new window for the 4 speed set up?
My window
I'm sure you could get one from B&M
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I didn't read this but it might have the info that you're looking for: http://www.carid.com/images/bm/trans...structions.pdf
Edit: Oh, sorry, I didn't see that you already found the info.
Car: 1984 Firebird S/E
Engine: 5.0L 305 V8
If you have a four speed trans but you don't remove the blocker pin and e-clips what problems would you encounter. My car has one of these shifters which was installed by a previous owner and I'm wondering if he did this due to some issues I'm having.
1 Post
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
My b&m shifter ripped out the rear metal mounting point from the car floorboard. Now I have to figure out ( no access to a welder) how to fix this.
Axle/Gears: 10 Bolt 2.73 Open
1 Post
Engine: 3.1 v6
Thanks dyno.
The entire rear mounting surface ripped out. So I got to remake that.
ZZ3Astro
08-13-2019 12:57 AM
