Need 700r4 to shift higher
1 Post
Car: 88 IROC
Engine: 305TPI
put my new engine in and it shifts way to early for the cam under WOT. I'm looking for 5,800 to 6,100 shift points for this 700R4 instead of the 4,900-5,100 that I'm at currently. What works the best? I'm sure I'm not the first to do this. What weight spring combo for the governor have you used to achieve this? 3.23 posi with a relatively low convertor(2200)
1 Post
Car: 88 IROC
Engine: 305TPI
Re: Need 700r4 to shift higher
Nobody have anything to say? I'm not looking for "Search" as a response. Between working full-time, school full-time I have very little time to research.
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
It's more of a trial and error deal when changing springs and weights. I do recall having to make fairly drastic changes in the governor to make decent rpm increments.
The best way to do this is to get a HI-RPM Corvette valve body and the matching governor. They have apx. a 6,000 rpm WOT shift point. The higher horsepower Z28 valve body and matching governor setup has apx. 5,500 rpm WOT shift point. The other option is to install the TransGo 700-2-3 Performance Shift kit, it will give you the ability to hold any gear to any rpm when manually shifting it.
UltRoadWarrior9
04-28-2020 10:39 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TheTraut88
09-07-2015 05:22 PM
