Spohn T56 TA crossmember
Old 10-18-2014, 08:10 PM
tehnation's Avatar
My spohn t56 ta crossmember tranny mount bushings don't line up with the center hole. It will if I use the one next to it. Does anyone know if this is the proper way to install?
There are 3 sets of threads on the tranny mount, when I put the stud in the center one it lines up with the hole on to the side of the center on on the crossmember.
Old 10-19-2014, 02:26 PM
builtforspeed's Avatar
Car: 90 camaro
Engine: AFR 195 comp 242/248 383
Transmission: dogbox t56
Axle/Gears: 35 spline s60 4.1 helical posi
Re: Spohn T56 TA crossmember
did you check the motor mounts are installed correctly?
Old 10-20-2014, 06:03 AM
Received 1,672 Likes on 1,269 Posts
Just move the trans over to the right place.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
kammi10
11-09-2015 08:28 PM
darwinprice
17
10-11-2015 11:51 PM
tmork454
09-29-2015 06:33 PM
Quick Reply: Spohn T56 TA crossmember
