where to buy a torsen differential
Car: 92 camaro
Engine: sb350 out of 88 pick up
Axle/Gears: 3.73 posi true track
hello I'm new to this form and new to third gen camaros. I have a 92 camaro and I want to change the differential in the car. I have done some looking around and I want to get a zexel torsen differential but I cant seam to find on. do any of you know where I can find one?
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I can sell you one. I need to get it out of the rear end I have. It's out of a 2001 z28. $50 plus shipping . You can look my user name up on here. Good feedback.
Car: 92 camaro
Re: where to buy a torsen differential
what size is the zexel torsen differential u have? will it fit my stock rear end?
Transmission: A4
Axle/Gears: 3:23
I told you what I had in private message yesterday. They are all interchangeable . 82-02 . Just need 28 spline axles . (Which you already have)
Car: 92 camaro
Ok. I know you said you have to take it out, when are you planning on dong that and could you send pictures when you do?
Car: 92 camaro
well I could not get straight answers from sellers, so I decided to get an Auburn LSD with cone clutches. I hope this holds up in my diff.
Car: 92 camaro
well because I don't know what is good and bad yet, I want to learn. I'm trying to learn and I cant get any straight answers from any one so I had a friend help me and he as an Auburn in his car, thus that's what I went with. I did a little digging and they seam like they should work but I know them. I spent about $400 on it so I really hope it holds up. I want help but no one seams to want to help. I'm new to the aftermarket world and this is my first car that I'v had the money to put into it and its the first worth it.
If you drive it somewhat normal and don't do any water burnouts or burnouts while holding the brake it will last a long time. If you do a lot of burnouts then plan on replacing it in about a year. If you have questions about a product then ask it here before purchase.
Car: 92 camaro
well I only put about 3k on the car per year and most of thous miles the car is not moving just the rear tires. I just blew the trans so I'm going to rebuild that and at the same time I'm putting in the Auburn. for when I blow this diff up what would you recommend? I was looking at getting a Yukon locker but I was told that a LSD would be better.
A locker kit that is installed in a standard differential case works pretty good for off road use. A lot of people use them in street cars, but they pop and jerk some. A Eaton Posi, Yukon Dura Grip or Eaton Truetrac will work smooth and pull both rear tires in all but the worst conditions.
Just a heads up, when you get the Auburn installed you should have 2 bottles of the GM limited slip oil additive handy. Use one bottle, but if it starts to pop when turning corners you will need to put the other bottle in. Most of the time the Auburn requires 2 bottles of the GM oil additive.
Car: 92 camaro
Ok thanks for the thoughts.
Car: 92 camaro
I WANT A TORSEN DIFF I CANT FIND ONE all the ones I find have a lot of miles on them or there look chewed up
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
You can find them on eBay, that's where I got mine. Torsen units don't have clutches that wear out like Auburns so as long as there isn't damage to the gears they're fine. And if you read some previous threads on this forum you would have known that torsens are far superior to an Auburn, the matter has been debated many times.
I hope for your sake you at least bought a new Auburn, as used ones could be smoked and you wouldn't even know it until you get it in the car & it won't spin posi. Also an important thing to note is that Auburn units require GM Posi additive in the gear oil. If you run it without this additive you'll damage the clutches and burn it out even faster than normal
When you say "chewed up" do you mean having marks around the outside where the pinion has been rubbing on it? If that is the case then I wouldn't worry much about it. As long as it hasn't chewed into the retainer plate or other important parts the markes aren't going to hurt anything.
The cone is a clutch, just in a different form. Some people on here will tell you not to use the additive, but if the rear end is popping when you turn corners then you need the additive. If it's not popping then don't use it. The only purpose for using the additive is to make it slip smoother when turning corners. It doesn't do anything else.
Car: 92 camaro
I know torsen is way better then auburn witch is y I want one. I started this post hopping to find one.
I bought a new auburn.
the gears are chewed like worn out.
cone clutches are one clutch on each side and its a cone shape witch is stronger then a multiple clutch set up, they are flat disks.
I know that you already have the Auburn, and I'm not trying to talk you out of it, but have you looked at the Eaton Truetrac? It's very similar to the Torsen.
Car: 92 camaro
no have not at all but I will look. If the Auburn is as bad as you'all make it sound then with the way I drive it will blow soon. thus I will need to look for a new diff. I'll check the Eaton out. I kinda moved fast to get the Auburn cuz I needed to get it and put in before the weather got bad so I put the car away for the winter.
You are not going to break the Auburn, it will just wear out quicker than any of the other units if you abuse it. It makes a mess inside the rear end too with all of the powdered metal.
Car: 92 camaro
The Eaton Truetrac is just like the torsen diff. I wish I know this soon. I'm got the return the Auburn and get a Truetrac, I have heard tow many bad things about Auburns.
Car: 92 camaro
I hate to leave something unfinished so... I did get a Eaton Truetrac I put new gears in at the same time. I love the way it hooks, it very predictable. I know when it will and wont slide and it always hooks up of a stop light. My wife liked it so much I just put the same diff in her s10 and she loves it.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Its nice when someone follows up like this and the fact he picked a truly great differential makes it even better.
I'm very happy with the "Eaton Posi" unit I have (clutch pack) but have my eye on the Truetrac if I ever need another one.
Car: 92 camaro
O and if you ever do winter driving just a heads up I was doing grate in about 6in of snow. I love this diff.
dbrochard
09-19-2015 08:13 PM
georgiaslim45
09-09-2015 08:12 PM
georgiaslim45
09-09-2015 08:11 PM
