T5 Clutch/Flywheel size?
Old 11-05-2014, 12:09 AM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
I'm thinking about using a 3rd gen F body T5 bellhousing, (in a non f body), and was wondering if it will accept a 168 tooth flywheel. (I'm guessing not)
Also, same basic question about the clutch, what will fit? 10.5", 11". or 12"?
(I'm sure a 12" won't fit, but I gotta ask.... LOL)
Old 11-05-2014, 12:42 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: T5 Clutch/Flywheel size?
Nope; will need a 153 tooth under a Thirdgen T5 bell.
Old 11-05-2014, 12:46 AM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
And a 10.5 clutch. At least thats what came stock in my car
Old 11-05-2014, 03:21 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
None of the thirdgen V8 bellhousings have a starter pocket past the right side of the bell. Any 168 bell starter pocket extends past.
An 88 vette clutch is 10.75 and that's what you can go with in normal stuff on the 153 flywheels.
Old 11-06-2014, 06:12 AM
TFS355S10's Avatar
Well that confirms what I thought anyway. I'll look into the 88 vette clutch for sure. I was hoping for a 11" clutch at least, but 10.75" sounds a little better than a 10.5". Lol
Old 11-06-2014, 06:27 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
McCleod sells a clutch & pressure plate that is 10.95 that fits I am using it, Dyno Don and his son use it, do a search... it's actually made for a Chrsysler, but it fits and people are using it...
Rafael
Old 11-06-2014, 12:48 PM
TFS355S10's Avatar
I was actually just reading about that setup this morning. I'll be looking into that pressure plate for sure. Not sold on the DF discs though. I'd rather stick with a stock style disc if I can.
Old 11-06-2014, 12:50 PM
luvofjah's Avatar
Mine feels really good, still not broken in yet... and good for 500 HP...
Old 11-06-2014, 02:04 PM
TFS355S10's Avatar
I always get a kick out of HP ratings on a clutch. That part makes no difference to me. I'd much rather see a torque/traction/heat rating. 500 HP is easy to hold with no traction.
Old 11-06-2014, 02:17 PM
luvofjah's Avatar
It is one of the more expensive clutches...
I don't think you're gonna find anyone saying McCleod is not a good product...
Old 11-06-2014, 02:36 PM
TFS355S10's Avatar
Oh I know McLeod is a good clutch/brand. I have no doubt about that. It's just the HP rating thing I was commenting on. HP means nothing without traction, but yet ya never see any mention of how many ft lbs of torque you can put to the ground. Heat kills most clutch discs, not hp.
Old 11-06-2014, 02:39 PM
luvofjah's Avatar
And it's the only option with an almost extra half inch more material on the outer edge...
I hope to be mating it up to my Astro A5 next week
Rafael
Old 11-06-2014, 03:20 PM
TFS355S10's Avatar
Yea, the extra 1/2" is good. I may go ahead and try it, but I want to do a little measuring first. Lol
What's a Astro A5?
I'm using a T56, but I want to get away from the junk LT1 style clutch and also the LS style internal hydro throwout bearing.
Old 11-06-2014, 03:32 PM
luvofjah's Avatar
A company that makes gears and components for the T5.
It is not GForce, they have their own better gears...
The top one is 575 Torque/650HP A-5 Transmission.
I only found about 2 members here that have it, very popular in the Mustang Camp, and any other T5 users that want more power..
It's about 3lbs more than the stock T5...
I did tons of research and found very few problems, one was from the owner himself, some car making over 500 hp, they replaced the mainshft to an upgraded one he sells and it fixed the problem... I've read about a lot of problems with the Gforce Stuff... Many people running in the 10's with Astro and slicks, no problems...
There is a thread here on TGO, old, but it has some neat info...
Rafael
Old 11-25-2014, 04:04 AM
TFS355S10's Avatar
Old post, but I thought I'd update, (and ask another question... lol).
I got a 153 tooth flywheel, and went with the 88 Vette clutch. Also got the McLeod t56 adapter.
Now my question is, does anybody have a part number, or a pic of a T5 clutch release fork? I've had the bellhousing for years, but when I dug it out I found I have no clutch fork with it.
I've got a few forks for chevy truck NV3500 transmissions and probably a few others laying around but haven't had a chance to dig that far yet. I'm guessing the NV3500 fork is different?
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
dbrochard
Interior Parts Wanted
09-28-2015 07:40 PM
Twinn Engines
South East Region
09-25-2015 06:25 AM
Quick Reply: T5 Clutch/Flywheel size?
