85 trans am , drive line clunk
Car: 86 t/a , 87 t/a
Engine: 305 tpi / 350 tpi
Transmission: 4 speed auto
hi guys , has anyone have knowledge on the following ? i have a 85 t/a , with engine running , shifting from park to drive at idle , i get a real clunk , almost like a lot of play in the driveline or something loose from underneath . the car runs fine through all gears , its just that initial shift from park to drive , is this a common trait of this model , or is there something thats a known problem in this area , thanks , luke , from down under .
Car: 88GTA
Engine: 5.7TPI
Re: 85 trans am , drive line clunk
Check your Transmission mount for one.
Depending on the mileage on the car, it could have rear end play and/or worn u-joint.
You'll have some play but these are things to start with.
thanks for the reply , will check on the above . i gather the rear end play will be in the diff assembly itself , has 105 thou on the clock . thanks
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
