TV cable doesn't ratchet when WOT
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I have a holley stealth ram backed by a rebuilt 700r4 and brand new tv cable from dealer and when setting the cable it doesn't ratchet. When the throttle gets forced to full throttle it makes a single pop and the slider barely moves. The cable is ran the shortest distance possible. The transmission feels like it's starting an 2nd gear and all the shifts feel to soon an the car seems to have no power. It engages all gears and locks converter. The cable has tension and it pulls smoothly and retracts back. Any help is appreciated. I have a pressure gauge on order.
Car: 1986 z28
Engine: 350 hsr
Re: TV cable doesn't ratchet when WOT
Update I put a pressure gauge on it last night and didnt seem to do anything.....no matter where I adjusted the black slider to the pressure never changed at idle..... I tried setting the slider based on instant pressure rise and that didnt occur until the slider was almost flush with the d tab. Leaving at this setting caused 2nd gear starts and mushy shifts
Car: check
Engine: check
Transmission: check
Disconnect the TV cable from the throttle lever. Start the engine and let it idle (best done warm).
Now pull the TV cable out and observe the line pressure. It should increase quite a bit as the cable is pulled out.
I don't have the pressure charts, but this should be done in each manual gear position to verify that the pressure is rising correctly.
RBob.
RBob.
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Is it a freshly built 700r4 thats going in for the first time after being rebuilt?
I just had a brand new tv cable do the same thing. I was able to set it same as the poster above(jmd), but without removing the pan. I felt for the tv plunger engagement, and set it just before engagement at closed throttle. I DO NOT recommend this unless you have researched the tv cable extensively. Cause a wrong adjustment can and will cause a toasty 700.
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
I have the same problem an taught it might be the bm shift kit I put in maybe one of the ball bearings or springs . My tv cable is the stock cable an iam running a Demon carb the cable is not kinked but even when you put on the tv cable it doest come out.
Car: 1986 z28
Engine: 350 hsr
No the transmission has over 100 miles on it....the tv cable never adjusted like it did when it was tpi but these symptoms are new an occurred with two different tv cables. I tried all different ways and the only way to get instant rise was with the slider slid all the way back. Any other setting and it takes a good bit of travel before there is any rise in pressure.
1 Post
Correct me if I am wrong RBob.
Car: 1986 z28
Engine: 350 hsr
Cable pulls out smoothly and retracts back as it should. Rbob that's what I thought as well but I had to slide it almost completely back to get instant pressure rise and when driven at that setting it starts in 2nd and stacks 3rd and OD. And I wouldn't think it would be a geometry issue since noone else seems to have ever had a problem with a stealth ram/700r4 combo
1 Post
Here is a quote from RBob on my turbo thread regarding the tv cable:
Stupid question, is the tv cable on the correct stud on the throttle lever?
Car: 1986 z28
Engine: 350 hsr
2 cars with identical engines, one knocks at 36° timing, the other doesnt. Each build is different even if its the same. That being said, is it a new or old TV cable?
TheTraut88
09-07-2015 05:22 PM
