Hydraulic clutch line replacement
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I'm planning to replace the plastic master cylinder to slave cylinder line with a braided hose. Is the Russell 64281 adaptor correct? I can't find a definitive answer for an 89 setup. Anyone used these?
Car: 89 IROC
Engine: 6.8 HSR N2O
Re: Hydraulic clutch line replacement
The Russell adaptors did work. I had to reduce the pilot od where the tip of the adaptor goes into the slave cyl but that may be unique to my aftermarket slave. Looks like it will be a nice setup and it's great to be able to disconnect from either end without having to deal with the pins. Plus now i have a braided steel hose.
1 Post
Car: 1991 Camaro Z28
Engine: 5.0 TPI
db057
08-11-2015 10:11 PM
rsrmoore
08-07-2015 08:44 PM
