700r4 shift problem
700r4 shift problem
OK I rebuilt my 700r4 and I can manually shift it but if try to just put in overdrive/drive it does nothing just like in nuetral. I was told it could be reverse sprag assembly backwards but it wasn't tore it back down to check any other ideas
1 Post
Car: 83 firebird 500 le
Engine: 350 chevy with 305 heads
Transmission: street/strip 700r4
Axle/Gears: chevy 10 bolt
Re: 700r4 shift problem
Hey mate I've had the same problem although the trans in my car has just given up all forward gears its at the trans repair shop the mechanic says it probably might be the governor?
Tried that tore trans back down 4 times could not find problem so bought another used trans to rebuild because first time have had the problem have 2 Cameros and pickup with 700r4 rebuilt all of them myself so while waiting on trans started driving car starting in drive then shifting to overdrive checking overdrive at every stop and it started working and that was 2 days ago trans now working perfect and still have no idea what was causing problem only thing can think of is I missed something when cleaning valve body
