leaking Return line?
Car: 86 Trans Am
Engine: 305 LB9
Had my car up on a lift at a shop having the starter replaced. While under there the mechanic showed me a transmission line was leaking on the passenger side on the bottom of the radiator. What line is this called? And is there an applicable part number. Also is it straightforward to replace or should I have the shop do it?
Also it was trans fluid leakiing and he went ahead and tightened the fitting
Car: 86 Trans Am
Engine: 305 LB9
