700 r4 torque converter.
1 Post
Car: 83 firebird 500 le
Engine: 350 chevy with 305 heads
Transmission: street/strip 700r4
Axle/Gears: chevy 10 bolt
Hey guys,
I was wondering if anyone could give me some pointers on what torque converter I should run in my firebird? Its got a 350 chev, 305 heads an I think that the cam is stock I would like to run an after market converter, just need to know what stall I should look at putting in it.
Thanks.
Thanks.
Car: 1988 Camaro
Re: 700 r4 torque converter.
With that combo I think a stock stall would be fine.. Maybe a 2000 stall at the most.
With Low rpm heads and low rpm stock cam, you are not making power high up in the power band, so no reason to use a higher stall converter.
When you move the power band up with bigger cam, bigger heads, etc then is when you need the high stall converter.
1 Post
Ok thanks for that will keep what I have currently running in the car. Just wasn't sure whether to change it out as I don't really know anything about torque converters.
Cheers Nat.
Cheers Nat.
Jed
01-03-2002 11:03 PM
