Aftermarket VSS?
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Aftermarket VSS?
I thought I had a fix to my VSS sensor behind the speedometer connecting to a 97 blazer overhead console, but I'm soon to be swapping in gauges and deleting the old setup (no more VSS) my trans is a th350 so it's all mechanical. Would I have to run the adapter in the trans that allows the speedometer cable to still connect but has the wire that comes off for an aftermarket VSS? Anybody have a link to something that will work? I have to match the PPM of the blazer (which I cannot find to save my life either a 2000 or a 4000 it's a 97 4x4 4l60) any help will work I'm at a standstill till I get this problem figured out.
Re: Aftermarket VSS?
Wiring is gone, because that VSS was on transmission I sold. I guess I could try an online manual, but I'm not sure it'd have that information
I believe it goes through the PCM too, but would this mean I have to do a complete PCM swap?? That's pointless on a completely mechanical car
TMZIrocZ350
10-07-2015 12:09 PM
