1987 firebird manual swap spedo question
Old 11-29-2014, 08:54 PM
chevy2424's Avatar
hey guys I have an 87 firebird with a 700r4 tranny I just pulled and swapping in a t5. i just realized that the 700r4 has an electronic spedo and the t5 is cable weird though they both are around the same year. anyways is there a easy fix for this? any feed back is appreciated thanks
Old 11-30-2014, 11:28 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: 1987 firebird manual swap spedo question
The VSS in the 700-R4 has gears inside. Pull the VSS and count them.
Put an 87 Firebird 5spd VSS in the T5 with teeth that match the ratio of the.teeth the 700-R4 had.
Old 11-30-2014, 11:36 AM
chevy2424's Avatar
Do you know where to get vss for te 5 speed?
Old 11-30-2014, 02:13 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The t5 you have must be from a CAMARO, firebirds switched to elec speedo in 86.
Vs for t5 are hard to find, the usual used part places might have it.
1992 Trans Am
05-10-2023 07:19 PM
jhawkeye
05-25-2022 06:33 PM
redmaroz
08-16-2015 11:40 PM
jahblah
08-12-2015 05:54 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: 1987 firebird manual swap spedo question
