Stupid Plastic plunger on a stock shifter
Old 01-13-2015, 09:27 AM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
89 Forumula 350 stock.
So the stupid little plastic plunger finally broke for good. Is there any trick way of replacing that thing?
While I'm asking anyone have a good way to remove the shifter cable without breaking the cable end, the one connected to the button.
I drilled a hole and tapped a small screw into the top what was left of it... It would not pull out.
A whole new shifter isn't that expensive ... I was just hoping to save time
Old 02-21-2015, 04:42 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Re: Stupid Plastic plunger on a stock shifter
You mean the white plastic beaded rod that goes down the center of the shifter shaft? It just pulls right out. If it's not effed up, it'd fall out by gravity with the shifter unbolted from the car and the **** removed.
If you mean the button itself on the **** broke, you need a new ****.
1992 Trans Am
05-10-2023 07:19 PM
Jeremys87
07-14-2022 09:08 PM
BewleyBizzIROC
02-03-2020 09:52 AM
Cleotiz
01-06-2018 08:56 PM
NBrehm
08-25-2015 11:49 PM
Quick Reply: Stupid Plastic plunger on a stock shifter
