Grease Clutch/Brake Pedal Bushings??
Car: 92 RS
Engine: 3.1 V6
Anybody know if the clutch and brake pedal bushings go in dry or is there a lube like lithium grease that should be applied to them?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Grease Clutch/Brake Pedal Bushings??
When I took mine apart last fall, there were no traces of grease or any kind of lubricant on them. I thought about greasing them as well before reassembly, but there is so much slop in the bushings it didn't seem worth it.
I actually took them apart to see if I could get rid of the slop(clutch pedal swings 1/2" either way), but couldn't find any replacements that would fit.
I turned down a bronze bushing from a fan motor to fit the clutch pedal. While I think the plastic ones give good life usually, I think the bronze will too.
I don't know if lithium is "right" for plastic bushed steel, but it should be fine.
Car: 1992 Camaro RS
I like bronze bushing idea. Do you have any more info on the bushings you used(OD,ID,length)? I wouldn't mind picking up a couple and trying it.
Car: 1992 Camaro RS
Do you remember what import? There's lots of them in the junkyards near me, and blower motors are cheap
