4L60e cooler lines
4L60e cooler lines
Doin an LS/60E swap in my 91 camaro, will my stock 700R4 tranny cooler lines work with a 4L60e (given the engine/trans placement isn't changed). Will i need adapters?
Re: 4L60e cooler lines
To use your existing 700R4 cooler lines will require threaded line fittings at the transmission. Most, if not all 4L60E cooler lines are quick connect type that use a "C" clip retainer so you'll need to swap back to a threaded line fitting.
Perhaps your fittings off your 700R4 will fit the 4L60E.
I don't know about the cooler line routing or clearance issues you may have.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
-- Joe
or
-- Joe
And straight thread is nps correct? I don't know much about the styles of these fittings. I went on dormans site entering a 98 Tahoe which would have the same transmission and it shows that is a correct fitting for that case, but npt. Just trying to get the right parts don't wanna ruin it anymore if it's not already ruined. Thanks
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I went through this. I removed the adapter from the 4L60E and replaced it with the adapter found on the 700 R4.
Yea I know the feeling. I just tried it and it worked. If I had the time and luxury of spending more money, I would have done custom AN lines because there is less headache down the road with routing everything.
