!!Not shifting into overdrive?? Trouble with 2nd and 3rd
Car: 1989 Camaro RS
Engine: 2.8 V6 TPI
Transmission: Stock 700R4 Automatic
Axle/Gears: Stock GU6 3.42
I recently bought an 89 RS V6, and when we were test driving it, the overdrive seemed to work fine. But now that I have been driving it for a few days it seems like the trans is having a little trouble shifting into second and third. BUT WILL NOT SHIFT INTO OVERDRIVE(60mph around 3500 rpm!)
But what will happen is it'll take a good 4000 rpm to shift from first to second, and sometimes with second to third, I need to just lower my rpm(coasting, neutral, etc) to at least 1500 and then it shifts.
The car had been sitting on and off, he started it and drove it every once in a while.
The trans fluid is pristine, he changed it three years ago and it still looks great.
Can ANYONE help??
Can ANYONE help??
Car: 1989 Camaro RS
Engine: 2.8 V6 TPI
Re: !!Not shifting into overdrive?? Trouble with 2nd and 3rd
Bump!
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
having similar issues. would love to hear any solution. but to the op try adjusting your TV cable. do a search its been covered
Car: 1989 Camaro RS
Engine: 2.8 V6 TPI
okay I think we have found the problem.
The front brakes have been sticking since it's been sitting so long, and the transmission is acting like there's a heavy load being pulled... After even a light drive and minimal braking, the front discs were too hot to touch
So I think just rebuilding the whole brake line will probably help.
Transmission: 5spd
Glsd you found tour issue. Doesbt reallt help me my brakes are fine
Car: 1989 Camaro RS
Engine: 2.8 V6 TPI
!!LONG OVERDUE UPDATE!!
after rebuilding the calipers, it still didn't shift into O/D(but accelerated MUCH better) I looked into this and adjusted the TV cable inward maybe 1/8 inch, and it shifts into overdrive properly(hopefully correctly) now.
Maybe this could help other people with similar problems.
84 TA NV
09-06-2015 08:02 PM
