T56 Torque arm relocation crossmember that works with UMI torque arm
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
Does anyone make a t56 Torque arm relocation crossmember that will work with a UMI torque arm? Spohn and BMR do not. I really don't want to have to buy another torque arm to make this work. Thank you in advance.
Received 1,664 Likes
Re: T56 Torque arm relocation crossmember that works with UMI torque arm
Suggest you take that up with UMI... they very well may have a solution. Give em a try.
Car: 89 Camaro RS
Axle/Gears: 4:10
I talked to UMI. They don't offer one for use with the t56.
1 Post
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
I made my own...I have a thread on here. Wasn't to bad and got to keep umi arm
Car: 89 Camaro RS
Axle/Gears: 4:10
I talked with Kyle at BMR and their's will work with the UMI torque arm. I got it in the car but the rearend isn't in yet so I can't get the torque arm in yet.
1 Post
Transmission: t56
Good to know. I think I would of went that route but needed to make it double hump style to clear 3inch y pipe with long tubes
1992 Trans Am
08-08-2015 08:16 PM
