How can I tell what rear end ratio I have?
87 GTA 5.7. I'm doing the manual swap and would like to verify what rear end is in the car. Is there a simple way to go about that via the VIN?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: How can I tell what rear end ratio I have?
100% sure is pull the cover and look at what is stamped on the ring gear. Or, count the wheel revs compared to drive shaft and divide. The VIN wouldn't tell you but the RPO code would but that assumes the original rear.
I think it's a 9 bolt. Have to check when I get home. Is the RPO sticker the one inside the arm rest? I have no idea what I did with it. I know for a fact it's the factory rear end. There isn't a build sheet stuck under the rear seat is there?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
It is. If the tag is there and all is original for sure then you're good to go. But....
Car: 1988 Camaro
I thought the only rear end option for the 1987 L98 F body cars was the BW 9 bolt, 3.27 gear
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
