lithium grease on carrier bearings
Car: '89 camaro
Engine: 305 tbi
Transmission: th700r4
Hi
I'm rebuilding my axle now and want to know if I should go with lithium grease on the carrier and pinion bearings or should I just apply that on the wheel bearings?
Thanks!
Thanks!
Car: '89 camaro
Engine: 305 tbi
Re: lithium grease on carrier bearings
Alright! Thanks
Just because I'm curious, I read somewhere that you should use lithium grease on wheelbearings but why/why not?
I don't know that it would be any better or worse. I've never used it in a rear end. I'm not a fan of mixing different types of lube in a rear end, or anything else. I know of several times that mixing lubricants caused major problems and complete failure. Squirting the same gear oil into the axle bearings that will be used in the rear end has always worked for me and I don't see a need to mix any other type of lube in the rear end.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Wheel bearings use bearing grease, bearing in the diff are lubricated by the gear oil in the case. Do not use anything else in the diff.
Car: '89 camaro
Engine: 305 tbi
aaah okay, must have missread somewhere. But seals should get some lithium grease right? I read that yesterday in the installation kit instructions
georgiaslim45
09-09-2015 08:12 PM
georgiaslim45
09-09-2015 08:11 PM
