Will rubber bushing from 700R4 torque arm mount work on a T5?
I can get the T5 mount, but the rubber bushing is bad. My 700 one is fine. Would I be able to drill it off and bolt it to the T5 one? Does it fit?
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: Will rubber bushing from 700R4 torque arm mount work on a T5?
Yes, you can drill out the rivets and use fasteners to mount the newer rubber. Just as an extra precaution, after you tighten the nuts on the screws, bend the ends of the screws a little to prevent the nuts from walking off.
Received 1,662 Likes
As long as the "lips" on your proposed rubber face the same way as the torque arm you wanna associate with it.
OTOH, as CHEEEEEEEEEEEEEEEEEEEEEEEP as new rubber is, who in their right mind would go through all that effort on a bunch of used-up 30-yr-old CRAP????
http://www.summitracing.com/parts/ens-3-1112g/overview/
3110 is the one with the lips tha tface the other way IIRC. Same price IIRC.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
