TKO 600 finding parts help
Car: 1987 z28 all stock + tricked 85 z28
Engine: 388 stroker + Procharger D1SC
Transmission: TKO 600
Axle/Gears: richmond 3:73, EATON, moser shafts
1985 Camaro z28 388stroker D1SC procharger w 3.40 pulley (up to 15 lbs boost) airgap intake holley blowthru from carbshop rpm heads w/2.20 in intake and 1.6 in exhaust scat h beam 5140 rotating assembly stock pan tko 600 5 speed with .64 5th gear top gun drive shaft old 10 bolt still holding it down for now with all new guts hotchkis TVS stock iroc rims wit 245s devils own meth inject kit with dual nozzle upgrade
i was bang shifting 3-4 turned fdown the boost retard a little and she was awesome! put it in 5th and there she stayed. u can put it in any gear and its 5th
i took her apart and found the 5th rail selctor is broke i heard it happens
found it on the service manual its part # TCBR4642
was reffered to a place in i think florida called promotion performance they said they had it but didnt call when they said they would and havent called me back so HELP!
Re: TKO 600 finding parts help
I've used http://thegearbox.org for close to 15 years. Kevin is there.
http://www.hanlonmotorsports.com/ Bob posts on thirdgen.
http://www.5speeds.com/ is Paul IIRC.
I'd recommend a phone call. And quit being a nancy about not getting calls when it doesn't fit your schedule.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Call Fortes parts in Massachusetts and ask for Mike Forte. He will get you the parts you need. He is the only distributor of TKOs in New England if memory serves correctly.
http://www.fortesparts.com
thnx guys one of these places should have it
86IROC112
08-17-2015 02:00 PM
