Clutch master ans slave cylinder replacement
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Ok question im wondering how hard it is to replace the clutch master cylinder and slave cylinder for T5 cars i dont know the last time they have been changed or rebuilt so dont want to chance it failing while out on the road cruising looks like the line isnt screwed into either like a normal mc and sc has anybody replaced these before
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: Clutch master ans slave cylinder replacement
The slave isn't difficult at all, but the master can be a bother. The trick is to go whole-hog and do it right. Disconnect the master cylinder pushrod from the pedal, then the mounting u-bolt on the firewall. The slave cylinder has only two bolts holding to the bell housing. Remove them, the hydraulic line and the reservoir together as an assembly if you don't want leaking fluid to hurt your paint. I found that separating the brake master from the booster (without disconnecting the brake lines) gave my arms more room to move. Use a punch to remove the roll pins that hold the master and slave to the hydraulic line. DO NOT REUSE THE O-RINGS. Your new cylinders will come with new ones. Once you have it all back together as an assembly, bleed the system on a bench like this:
If you do it this way, you will know the system is good before you even put it in the car (so long as you don't take it apart.) Put it back in the car as an assembly, put everything back the way you found it and enjoy!
