Can clutch master cylinder push rod be removed?
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
Hey folks. Anyone know if the clutch master cylinder pushrod can be removed so i can leave everything in place? I'd like to just pull the rod so I can modify the length
I have the t56 hydrolic with the third gen pedals. The height of the clutch pedal is super annoying
1 Post
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Can clutch master cylinder push rod be removed?
There should be a snap ring, but to access it you probably have to remove the master from the car.
If there is enough extra thread, shortening the pushrod in place may be possible, I just did this to a non-third-gen, but you may need to remove the pedal to do it. Modifying the pedal arm may be an alternative.
Been too long since I did a clutch pedal in a third-gen.
