trans & torque arm mounts
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
its time to replace the trans mount and torque arm bushing on my 86. i would like a strong poly urethane trans mount as well as a poly TA bushing. who uses what? and where did you get it? oh, its a 700R4 trans and the car is all stock
Received 1,664 Likes
Re: trans & torque arm mounts
ES, Summit.
I still wasn't happy with the TA though. I ended up getting a Spohn one, not long after he first came out with em. It was the old "slider" type, that I think he quit making in the late 90s sometime and switched over to the 2-bushing rotating deal. Putting that in felt like taking a giant rubber band out of somewhere REAL large and important in the drive train; made the car feel altogether more solid and interconnected than the limp floppy stock setup.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
The Energy Suspension torque arm mount bushing and trans mounts work well.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Just beware of the poly trans mount if you don't already have poly engine mounts. There are tons of people including myself that had terrible vibrations doing that combo. I put a stock trans mount back in and it all but went away. Oh well.
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I went through a few ES Transmission mounts. Summit Racing was kind enough to allow them to be returned.
Finally I went to my local Auto Zone and bought the ES #3.1108G again and this time I installed it
"without" the preload plate and it works perfectly.
I also have the ES Motor mounts so there has always been some vibration.
Its not enough to see in my rear view mirrors and good enough for me.
So if your going to roll the dice on a ES Trans. mount it might as well be the one that worked for me.
After all it is the one listed for you car =
http://www.autozone.com/drivetrain/t...artNumber=true
LT1Formula
11-16-2015 01:13 PM
