Surprising MPG results with 4.10 gears
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Here is the powertrain: Moser 9" with 4.10's and locker diff, 700R4 with a shift kit, bolt on L98 (est 300hp). 18" wheels (25 1/2" tire). Car is 200 lbs lighter than stock.
The speedo is off and the odometer counts wrong. I used my GPS on my trip today. I topped off the tank before and after. I drove 80 miles (70miles highway 10 miles city). Set the cruise @60mph RPM @2250.
I used 3.75 gallons = 21.33 mpg!?
Maybe that's normal? I was estimating 16
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Surprising MPG results with 4.10 gears
There's a margin of error in topping off, doesn't always shut off at the same point. Need to measure after using a larger amount of gas to minimize the margin of error. At least a full tank.
Car: 1991 Z28
Engine: 5.7 TPI L98
I was thinking that. I think I had gas up the filler neck on the first top off. I may never know because this car never gets filled past half tank until yesterday haha.
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
