quick converter question
Old 06-27-2015, 09:30 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
th350
if you stick your finger in the converter, and the gear, (sprag?), moves in both directions,...is the converter broken?
its a 10", 3,000+ stall. just wondered if thats normal? im told no.
thanx for any help,
Joe
Old 06-29-2015, 02:50 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: quick converter question
bump
Old 07-03-2015, 11:27 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
ttt
Old 07-09-2015, 04:34 AM
Pro Built Automatics's Avatar
You cannot tell anything that way. What makes you think the torque converter is bad?
Old 07-09-2015, 07:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only way to know the condition of the converter is to take it to a shop that rebuilds them and have it cut open. If everything checks out, and the case is still in good condition, they can weld it back up.
I had a converter that was acting up. I took it to a local rebuild shop. When they cut it open, a torrington bearing had failed and the fins between the two halves were making contact with each other. I stood there while they cut it open for inspection. They repaired it a few days later the best they could but I still wasn't happy with the performance so I bought another.
Brand name performance converters does not mean it has good parts inside. Normally with a converter, you really do get what you pay for. My current race converter was custom built and was over $1200 and it works beautifully.
69 Six Pack
10-05-2015 07:51 PM
Fronzizzle
08-19-2015 01:36 PM
redmaroz
08-16-2015 11:40 PM
happyhapka
08-15-2015 04:42 PM
gta power
08-13-2015 06:15 AM
Quick Reply: quick converter question
