Clutch wont bleed....HELP!
Hey guys,
Put a T56 in my 85 camaro. Same master cylinder but I put the 87 Cavalier Slave on it. I was told this works fine. Anyways, Ive been pumping and bleed and pumping and bleed and I am getting NOTHING out of the clutch. Wont budge. I hear fluid moving in the slave but no action from the slave. Any ideas or tricks to get this thing goin?
Thanks!
Thanks!
Re: Clutch wont bleed....HELP!
My guess is the master does not move enough fluid. A couple ideas to try. Best is to pressure bleed of you have a way to force pressure thru the clutch master cylinder reservoir. 2nd is vacuum bleeding with slave bleeder closed vacuum from master reservoir. 3rd gravity bleed. All these fail is $$$ but sure fix is a tick performance master but it's $3xx. It has a big bore and moves way more fluid. Also for the Caviler mc have a restriction in the line ( it will be where line leaves the mc) the 4th green ones do
What is the 93-97 F bleed method?
Thanks!
