Hydraulic Clutch for Saginaw 4-speed?
Car: 1982 Camaro Base
Engine: 151 cid Iron Duke
Transmission: Sag 4-spd
I have an '82 that came from the factory w/ a 4-cylinder TBI & a Saginaw 4-speed. I still have the factory engine & tranny, so I decided to build it back to original; but I'd like a hydraulic clutch.
The question: Is there such a thing as a Hydraulic TO or a Master/Slave for the Saggy 4-speed? I do have a spare Master/slave setup from a WC T-5 if there's a bell housing that would be compatible.
Thanks Guys!
Thanks Guys!
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Hydraulic Clutch for Saginaw 4-speed?
a stock later clutch master cylinder with an aftermarket hydraulic throwout bearing would seem to be the setup you need.
this should get you started:
http://www.summitracing.com/search/p...rder=Ascending
Seems like it should be easy enough to swap. Thanks!
