Broken mount?
Car: 86 Trans Am
Engine: 305 LB9
Broken mount?
Not sure if I officially broke a mount today. Was in a ruse and put it in drive at about 1200 rpm after startup. When I put it in gear it made a loud bang.
My car always made a loud bang when going into gear, not like the tranny was hitting anything but more sounded like a transfer of power on old parts on the drive train.
I put it into drive and reverse after I got home and it still sounded loud but not as bad as the first time tonight. I got under it and had a friend change gears and I didn't see any noticeable movement on the tranny. Should I be okay?
Edit: ran out again and the tranny sounds okay when I put it in gear again.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Broken mount?
A broken/tore rubber transmission mount can be hard to see until you lift the transmission a little bit.Then you will see that the rubber actually ripped away from the metal part of the mount.
Received 1,662 Likes
Re: Broken mount?
Put a floor jack under the extension housing.
I'd almost bet money the mount is broke; they about always are.
Car: 86 Trans Am
Engine: 305 LB9
Re: Broken mount?
Got under it with a floor jack today and it is broken. Ordered a new one online to have in before my long tri . Anything to keep this thing running good for a long time
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
