a little unclear on the 7.5 carrier
1 Post
Car: 1984 Chevrolet Camaro z28
Engine: 383 sbc
Axle/Gears: Stock...this is next
Hi guys,
So I've read through the FAQ on the ten bolt. Garbage I know, but it's what I got. Here's the plan.. upgrade my 84 Z28 rear end (currently 3.23 open rear 7.5" with 26 spline axles) to a 3.73 posi with 28 spline axles. I'd like to keep my rear diff, so I don't have to buy new wheels etc as if I went with a 4th Gen rear. My question is, can I buy the 7.625" 3.73 gears and either a 7.625" Eaton Truetrac or Powertrax No-slip unit with the 28 spline axles (and then Moser or Ten axles) and have it all fit in my 7.5 rear that I already have, or do I need the bigger carrier to do all that upgrading? Thanks a million
Re: a little unclear on the 7.5 carrier
The 28 spline Power Trax No-Slip will not fit in your 26 spline differential case (what you are calling the carrier). You will need a 28 spline case for that. I'd recommend getting a complete differential instead of using the No-Slip. Power Trax makes a Grip LS that should work well.
1 Post
Engine: 383 sbc
Oh OK, see that's what I've been unclear on. I'll look up the powertrax unit. Grip LS? Will that necessitate a 4th Gen rear?
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I put a 28-spline 4th gen Torsen Posi in what was a 26-spline rear, out of an 86 Z28 and used 28 spline moser axles. I don't know about the aftermarket diffs or why they woulldn't work, but everything went together perfectly.
All of the 7.5 and 7.6 differentials will fit the 3rd and 4th gen housings. You just have to match them up to the correct axles and other parts. As long as all of the parts work together it doesn't matter if it's a 7.5 or 7.6 housing.
georgiaslim45
09-09-2015 08:12 PM
georgiaslim45
09-09-2015 08:11 PM
