How important is it to disconnect driveshaft when dolley towing? Going 1400 miles.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: How important is it to disconnect driveshaft when dolley towing? Going 1400 mile
Depends on how much you want your transmission to work when you get there.
Seriously, DS installed turns the main shaft. You'll be in neutral whichever tan you have. For manual, neither the input nor (more importantly) counter shaft will be turning to move the oil to lubricate everything. The bearings will spin dry, then hot, then gall and fail. Auto is similar; without the TC turning the oil pump, no oil flow, dry bearings, burnt trans.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Never realized that's the reason your not supposed to flat tow em, but when you put it that way it's probably best to take the 5 minutes it takes to pull the shaft.
Car: 87 IROC
Engine: L31 350
Don't forget to plug the tailshaft so you don't leak a bunch of oil, especially with the nose up position!
kammi10
11-09-2015 08:28 PM
