Removing B&M Shifter
Car: 1989 IROC CAMARO
How hard/time consuming is it to remove and install a stock shifter back in? Is it worth calling a mechanic or doing yourself?
Car: 1988 Camaro
Re: Removing B&M Shifter
No man, you can do that yourself.
It's pretty simple as long as you can jack car up and support it and lay under there for a few min to un hook and hook up cable.
Start to finish should be less than 2 hours for somebody that's never done it before
Car: 1988 Camaro
I don't even see the **** in that picture man. I know I placed the button inside the **** and wrapped it in bubble wrap... I should have one more auto shift **** and button for a camaro. I will send you that button at no cost to you.
Thank you for your "order". Sorry for the misplaced button.
Car: 1988 Camaro
I have you a shift ****, button and clip wrapped up and will send off tomorrow. I am sorry for the inconvenience.
WildCard600 (02-03-2020)
