700R4 lags and doesn't like leaving overdrive
Old 08-29-2015, 10:25 AM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
Axle/Gears: 10 Bolt 2.73
Whenever I'm cruising in overdrive and decide to accelerate a little bit, I have to go almost wide open for it to shift out of overdrive, which causes it to downshift way too low and rev around 4k while pulling really hard. I've been driving with overdrive off because of this unless I'm driving long distances on the highway.
And whenever someone in front of me puts on their turn signal and slows down to turn, and I try to accelerate after they turn, it revs up like it's in neutral and then it all of a sudden shifts hard and pulls. It didn't start doing this until recently, and I'm not sure what it is, but I'm sure I won't like it.
Old 02-19-2016, 08:27 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Re: 700R4 lags and doesn't like leaving overdrive
how old is your transmission? how often do you get it serviced? you might want to take it in for a check. i would actually start with the TV cable first, might be out if adjustment.
Old 11-07-2020, 09:23 AM
Dan Pritchett's Avatar
wrong page
Vinscully50
05-09-2017 12:19 AM
Darkshot
12-04-2008 07:54 PM
apinaire
03-07-2005 06:03 PM
84camz28
11-13-2004 09:18 PM
Quick Reply: 700R4 lags and doesn't like leaving overdrive
