89 clutch is spongy
Car: 89 Camero RS Convertible
Transmission: Manual
Axle/Gears: Stock
89 clutch is spongy
89 with 84,000 miles. Sits most of the time. Clutch started feeling spongy. Sometimes it just won't work, then it starts working again. Doesn't matter if it is cold or warm. Seems to not work more often when in reverse. If I add fluid, do I have to bleed it?
Car: 91 G92 Z28
Axle/Gears: 342
Re: 89 clutch is spongy
You probably have questionable seals in your master and/or slave cylinder. I'd start with replacing the slave down on the transmission since it's subject to more weather and grime.
