Cooler line fittings again !
Car: 1984 Z28 HO
Engine: GMPP 350 HO
Transmission: 700R4 w/TCI streetfighter kit
Axle/Gears: 3.73 28 spline Eaton posi
Hey all . I did a search on the forum and really didn't get the answer I was looking for . I need to know what size the hard line fitting is so I can order the correct an6 adapter for the radiator side . The closest I could find is 1/2"-20 inverted flare for a th350 . Is the 700r4 the same ? I am replacing the trans adapter to a 1/4" NPS x an6 , but I need the adapter for the radiator side of the connection . Is it 1/2"-20 inverted flare as well ? I am replacing the hard lines with stainless braided . The help is appreciated !
Received 1,672 Likes
Re: Cooler line fittings again !
Yes they are 5/16" inverted flare, the thread on whose nut happens to be ½"-20.
ambainb
04-25-2016 09:21 PM
