Rear swap questions!
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
Okay guys so I've been saving a 1992 camaro I got when I was 15 was originally a v6 scrapped that got a small block going in with a new trans. New springs new strust and shocks new brakes and I figured I should beef the rrar up some so Im getting a 3.27 posi rear from an 86 trans am it's a disc brake read mine was a drum ik in they bolt up I'm just wondering is there anything special I'm.gonna have to do with the e-brake. I hear the rear swap.is a fairly easy job with some air tools
Re: Rear swap questions!
I swapped a 1988 3.45 ratio 9-bolt with moraine disc brake rear for the 3.23 ratIowa 10-bolt drum brake rear end. I did not need to swap the proportioning valve, however I did have to swap the emergency brake handle and assembly from the 88. The older style e-brake has the ability to adjust the length of the cable at the yoke where it splits from one cable to two. Yours lacks that adjustment. I also swapped in new e-brake cables.
Lon
Lon
