V8 T5 Shifter location.
Old 09-29-2015, 04:07 AM
AUZ28's Avatar
Car: 87 Z28
Engine: 5.0 LG4
Transmission: 4L60 (Built)
Axle/Gears: 3.23 Eaton TrueTrac
I've tried searching and didn't find what I was looking for.
I'm After the distance the from the front on the bellhousing to the shifter on a V8 T5 gearbox. Hopefully someone has one lying around they could measure up.
Cheers
Old 09-29-2015, 10:22 AM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: V8 T5 Shifter location.
If you are looking for where to cut the hole in the transmission tunnel, just look for the dimples.
Cutting the hole for the manual shifter.
Old 09-29-2015, 03:52 PM
AUZ28's Avatar
Car: 87 Z28
Engine: 5.0 LG4
I'm Really after the distance from the front of the bellhousing to the base of the shifter on the box. I got given a toyota supra 5 speed which has a custom chev v8 bellhousing on it. I have measured up the gearbox mount and it is only 1/2 inch off the stock 700r4/T5 location so I can make that work. I just need to find out if the shifter is close to where it needs to be. Thanks for the info on where to cut the hole though.
Old 10-03-2015, 06:21 PM
BrianI's Avatar
I have T5 and bellhousing in my garage. I'll try to get a measurement tomorrow
Old 10-03-2015, 06:28 PM
AUZ28's Avatar
Car: 87 Z28
Engine: 5.0 LG4
Thanks Mate, that would be awesome
mcfastestZ28
10-05-2015 07:12 AM
ndndndnd
09-28-2015 08:00 AM
Quick Reply: V8 T5 Shifter location.
